Is U.S. iPad HDMI "international" format for output?
This may be (ok is) a dumb question; but does HDMI output suffer from the old international standard problems as TV did with regional encoding and incompatible international video formats?
Will a U.S. iPad be able to send output to a British, French, etc. television via HDMI and work?
Just had a sudden “fear” when thinking about traveling w/ my iPad – Thought I could let a group use it as a device to draw on, while plugged into a TV, and show some cool presentations, live-mark-up, etc.
THEN I thought, "Wait, what if the iPad output suffers from the “Great ‘NTSC/SECAM/PAL Divide’?!?” … “And, heck, what about frequency refresh?!?”
I know many of our MPU leaders and listeners travel a lot and no one has mentioned this on the podcast to my recollection.
Does that mean that particular concern has been banished by HDMI and/or the digital broadcasting ‘revolution’?
Thanks!
–Tim
P.S. Tried to answer this question via Google and got a lot of ads for adapters…
It should be no issue.
Living in a PAL country, I do not have experienced any problem since I got my first digital LCD TV many, many years ago. NTSC works as does PAL.
Still, for instance Lifewire points out that there still are differences:
The thing is that I do not see issues. TVs work both with PAL and with NTSC and I would guess that SECAM does not make any difference.
Super! Thank you!! [Did you know that our posts need to be at least 20 characters, or we can’t send them? — Jence my adding this :wink: … ].
I’ve used my US ipad and iphone via HDMI in South Africa and Australia with no issues.
Great article by Lifewire. Just to add one piece of info I could not find there: the design decision to go with 25 or 30 frames a second is based on the country’s electrical grid freqency of 50Hz or 60Hz. Frame timing is right there in the power supply.
