Open Keynote, click Edit in the menu bar and see the sixth element is “Paste and Match Style”.
Install Karabiner Elements and add the following
karabiner.json
:{ "global": { "check_for_updates_on_startup": true, "show_in_menu_bar": true, "show_profile_name_in_menu_bar": false }, "profiles": [ { "complex_modifications": { "rules": [ { "manipulators": [ { "description": "Change caps_lock to control+option+shift+command.", "from": { "key_code": "caps_lock", "modifiers": { "optional": [ "any" ] } }, "to": [ { "key_code": "left_shift", "modifiers": [ "left_control", "left_option", "left_command", ] } ], "to_if_alone": [ { "key_code": "escape" } ], "type": "basic" } ] } ] } } ] }
Open System Settings, click Keyboard, Keyboard Shortcuts, App Shortcuts.
Set Menu title to Paste and Match Style and the Keyboard Shortcut to Caps Lock-V (that is, Control-Option-Shift-Command-V).
Open Keynote, click Edit in the menu bar and see the sixth element is now called “Paste and Preserve Style”.
Why does its name changed? And why, despite Caps Lock-V works fine to paste and text and match/preserve style, the Paste and Preserve Style item is always greyed out in the menu?
