Anyone else getting not infrequent kernel panics on their M1 MBP? Perhaps once a day for me. It’s hooked up to a CalDigit TS3 Plus Dock connected to an Ultrafine 5k and a bunch of peripherals/drives. I also have Backblaze chugging away uploading my data.
It seems to happen most often when I disconnect the dock after a few minutes, though there are plenty of others times as well.
This is is a basic question, but does anyone know if/how I can find out what triggered the panic specifically? E.g., if it’s something due to switching from Ethernet to Wifi, or disconnecting from drives, or the display configuration changing, etc.?
Hi all, thanks so much for your replies. It seems that the culprit was a drive containing a bootable clone of my Mac pre-Big Sur. I kept it on a partition on the same drive that did my time machine backups. Once I moved those off it seems that all is working just fine.
