I’m probably getting an iPad Mini A17 (again, after many years).
My OG iPad Mini was paired with a Logitech keyboard that magnetically attached. (The back was unprotected but that was OK.)
What are the options you could recommend for the new iPad Mini?
The keyboard is an essential part. One of my use cases is on a table, either in a coffee shop or on a plane, so the iPad needs to be able to stand up. The old one stood in a slot in the keyboard.
If you are OK with having a separate stand, the ProtoArc folding keyboards are pretty great.
If you want something more compact, I picked up this one for my iPad mini and it works well despite coming from a brand I’ve never heard of: Amazon.com: GreenLaw Keyboard Case for iPad Mini 7(2024) & Mini 6 (2021) 8.3", Touchpad Keyboard with 7 Color Backlit, Type-C Rechargeable, 360° Rotate Keyboard Case for iPad Mini 7th/6th Generation, Black : Electronics
Thanks. The latter is one I found on Amazon UK. It’s not ideal but might well do.
