I’d like to create a macro for keyboard maestro that will create a low battery power environment for my macbook pro. The key note always says the battery power should last about 12 hours, but mine lasts about 5… So:
I’d like to adjust the brightness to about 40% when it’s on battery, close background apps, and consume as little power as possible
Any of you got the solution to this one??
Here are the steps I do:
- Using KM, dim screen 10 steps to get to Black, then brighten 4 steps. Adjust how you bright you like it. KM has an action to brighten and dim screen.
- download
blueutil
to turn off bluetooth
/usr/local/bin/blueutil -p 0
echo PASSWORD | sudo -S mdutil -a -I
off to turn off spotlight indexing
networksetup -setairportpower en0 off
to turn off wifi
I don’t like auto closing apps. I think I heard Marco Arment as an app for that.
Yeah, that is Quitter, I have that installed
