Back in September, my LaCie 2Big Thunderbolt 3 Dock started acting odd and noisy. Flashing blue light turned into flashing Blue then Red light. My 2018 Mac mini would crash randomly. The 2BT3 Dock was getting warm overall. Researching this issue led me to believe one of the HDDs was failing or the internal fan on the unit may be clogged. Powered down the system, pulled both HDDs and used some compressed air. Some dust/debris was present but not enough to stop the fan. It spun freely with little effort. Reassembled and powered back on to same results. Since this was setup as RAID 1, I decided to see which HDD was failing. Opened the lower bay and pulled drive out slightly. Lo and behold… Light went back to solid blue and mounted on desktop!
OK this is a start in the right direction. I purchased the LaCie 2BT3 Dock in 2014 and almost 10 years of life on an Enterprise grade HDD was a pleasant surprise. (Hadn’t realized how long I had owned this setup) There were 2 - 10TB HDDs installed and I believe we all can agree that when one starts to fail the other one is not far behind. I went shopping for 2 new HDDs and was shocked to find that I could upgrade from 10TB to 20TB for just $30 more per HDD. Drives in the 12TB -18TB range were over $100 higher in cost than the 20TB. Not to look a “gifted horse in the mouth” I quickly placed my order.
Week later the new HDDs arrived and installed one in the lower bay and started to rebuild the RAID 1 setup. Took just over 26 hours for 6TB of data. Moved the new HDD to the upper bay and started the process again. This time it only took 18 hours. I was back in business and happy again!
Until last week when the flashing lights started all over again and the Mac mini crashed. Pulled the lower bay HDD out and the Dock mounted, but only for a few hours. The LaCie 2BT3 Dock will not mount on any computer we have ![]()
I contacted LaCie/Seagate support back in September and again last week. Frustrating may be an understatement when comes to working with their support team. I am a longtime and loyal fan of LaCie but now I question that loyalty. After mentioning multiple times that “I was YEARS outside of warranty” and just wanted to know if they could sell me a drive-less 2BT3 Dock, they read their script and told me I didn’t qualify for any warranty coverage. They did tell me I could ship the unit to a Service Center for a quote. After looking into that possibility, it seems the only Service Center in the US is a Logistics Company in California who told me they don’t do repairs there but can ship it to LaCie/Seagate IF I have a repair number…
I think I am done with them… Thank you if you have made it this far!
I have tested both of the 10TB and 20TB HDDS with an OWC “toaster” HDD sled. All 4 HDDs passed testing in Disk Utility. I can see data on all 4 HDDs. I have this data copied on other HDDs as well.
What alternatives should I consider???
I truly enjoyed the simplicity of a connected unit with all my Music/Moves/Photos and documents on it. A few friends have suggested of upgrading to a Synology setup. Another brought up OWC’s hardware.
I am setting up a Hardware closet for my router, switch and Hubs so maybe a NAS isn’t such a bad idea.
Bring on your Suggestions and Opinions!
