Does anyone know how I can use the launcher app to just press a button and take me to JFK, LaGuardia, and Newark airports in NYC and NJ? I can’t figure it out. I would like to do it using Waze. Any suggestions?
You’ll need to have the longitude and latitude of each of those locations.
Assuming you’d like one button for each, here’s how you’d set that up. In Launcher, under the Waze settings, select the “Navigate Here” option. Then, enter the longitude and latitude separated by a comma. Make sure to remove any special characters and letters. Change the label and you’re good to go.
Edit: if you happen to be at one of these airports, you can use the special “meta launcher” to pull the location data. That’s listed under “Special Launcher” > “New Waze Go Here Launcher.” Every time you press that launcher, it pulls your location data and adds it into the Waze URL scheme.
