Quickly plan your next laundry session from a lock screen widget. All it takes is two taps!
Main Workflow:
https://workflow.is/workflows/31cc4fdb2f4a44e5a9cdea3e360c7005
Two helper Workflows with functionality extracted from main workflow for readability:
https://workflow.is/workflows/87ca2e0782ed4daaa199b334bf1fb370
https://workflow.is/workflows/7636e695d6544259aec37a6acf024259
The user first selects a date from a list of 14 upcoming days, then selects one of a few user-defined time slots. An event is automatically added to a calendar specified by the user.
Note: It is made for 24h time format. Some tweaking is probably needed for 12h time format.
Edit: Correct links.
Google Calendar added something called Google Goals. Tell it you want to do anything X times week/month, and it will suggest a time thatâs open on your calendar, which you can accept or veto. Then if youâve done it you check it off and GC set the next appointment based on your criteria. If you donât do the laundry when scheduled instead clock âDeferâ and the appointment will get moved. Its AI also learns when you donât want to do something (or didnât do a scheduled goal) and tries to make better future suggestions. More here and here.
It may not be a workflow but itâs one more reason I use Google Calendar. The AI is surprisingly useful, gets better over time, and automatically gives me lock-screen alerts if desired.
Thank you for the information, I did not know of that functionality. It sure sounds useful if the only constraints for selection of laundry times is in your calendar. I live in an apartment with a shared laundry room, so there are only certain slots available, which makes a âlow-techâ solution suitable.
Out of curiosity: do you use Google Goals for more tasks than scheduling of laundry times?
Yes! For goals Iâd like to squeeze in but donât want to have to explicitly set times for. The example Google itself uses in its intro video is learning a foreign language.
To set a goal (like âWork out moreâ), simply answer a few questions (like âHow often?â and âBest time?â), and youâre all set. From there Calendar will look at your schedule and find the best windows to pencil in time for that goal. More info here.
