I have a question concerning a Motion sensor and a lightstrip (both from Eve).
I would like to have that the light strip switches on when the motion sensor detects (this works) and stays on when motion is still detected (not working).
I tried:
- setting light strip to switch off after 5 / 2 minutes which works in the way that it switches off, but not on again, and does not sta on when movement is there
I could not find a solution for this, apart from writing a shortcut to achieve this. Is there no easy way of achieving this basic task of a motion sensor?
