Will Logitech R500 clicker or any other Bluetooth clicker work with iPad running iPadOS 15 for presentations in MS powerpoint? I don’t use keynote.
Have you considered importing the PowerPoint presentation into Keynote?
These physical remotes should work with PowerPoint on iPad. They also should work for advancing through PDFs and a few other unofficially supported apps.
Thanks for the response. I find it easier to work with MS power point in iPad as I can jump between slides in between animations. That’s a feature I need as I am taking classes on tax laws.
Oh thanks for the response. I guess I will get R500 from Logitech.
