I need to install Proxmox on a new PC system and I only have a MacBook to create the bootable USB for install Proxmox.
I have already downloaded the .ISO file for Proxmox.
What software is commonly used to do this on a Mac and be able to use it on a PC based system?
Give Balena Etcher a try. That’s what I use to create bootable disks from an ISO
It’s pretty straight forward to use. Just pick the image (iso), the target disk, and then set it off.
This is the right answer.
Balena Etcher, hands down.
Thank you Sir!
Balena Etcher worked good and now my Proxmox hypervisor is running!
