I bought my current MacBook Air 2019 back in August. I went through a fresh install and all went well.
After a month or so of using it I noticed that the rainbow spinning wheel kept showing up from time to time… usually with Pixelmator Pro. Even though it was for light photo manipulation I thought it could be just that causing it…photo manipulation always consumes resources right?
However, now I’m noticing it also with Excel (with little things like changing a cell colour).
Any ideas of what might be causing it and how to solve it?
This is Macbook’s configuration:
13-inch MacBook Air - Space Grey
1.6GHz dual‑core 8th‑generation Intel Core i5 processor, Turbo Boost up to 3.6GHz
Intel UHD Graphics 617
16GB 2133MHz LPDDR3 memory
256GB SSD storage
Thanks!
PS - I’ve heard about resetting the System Management Controller (SMC), and one of the symptoms is as per the below…but I’m not sure whether this could be it…?
“Your Mac performs unusually slowly, even though its CPU isn’t under an abnormally heavy load.”
