Make a simple shell script easier
I have a simple one-line shell script that I use to OCR a PDF file (or re-do the OCR if the existing layer is bad).
Right now this means navigating to the file in Terminal, remembering (or looking up) the command, pasting or typing in the target file name and then typing in the destination file path. It isn’t hard, but I’d love to automate it outside the command line, with a default destination path (e.g., in the same folder with the existing filename but appending ocrYYYYMMDD or similar).
Any suggestions for the best approach? A service? Is there a way to drag-and-drop a file onto something? I could easily use Keyboard Maestro, Hammerspoon, AppleScript python or any number of other tools. Learning Swift to create an actual app seems like overkill.
Perhaps try:
I think(?) simplest way would be a shortcut with a run shell script action? And then have the input be PDFs. (Basically a service)
Depending on the complexity of the terminal code and/or input choices you desire, put the shell script inside an AppleScript. Use Automator with the tab “Run Shell Script”. Put a pointer to the AppleScript inside. Save in the ~/Library/Services folder. You can then context click on the file to find the service and run it. And, since the shell call is encased in an AppleScript, you can select files and run the AppleScript on them.
Here is my example to crop margins on documents to 1 inch all around. I have a separate AppleScript that prompts with a dialog to take a setting value to crop the margins.
Crop Margins to 1 Inch
Service
AppleScript
	crop PDF document margins
	author: jjw
	version 1.1
	-- sets margins to 1 in all around
use AppleScript version "2.4" -- Yosemite (10.10) or later
use scripting additions
property pdfcropi : "/usr/local/bin/pdf-crop-margins -gsp '/usr/local/bin/gs' "
property pdfcropf : "-p 0 -a -72 -mo -o "
on run {}
	tell application "Finder" to set theFileList to selection
	if theFileList is {} then return
	if (count of items in theFileList) > 1 then
		set pf to "-pf "
	else
		set pf to ""
	end if
	set pdfcrop to pdfcropi & pf & pdfcropf
	repeat with theFile in theFileList
		if the kind of theFile is "PDF document" then
			tell application "Finder" to set theFileAlias to theFile as alias
			set theFilePath to POSIX path of theFileAlias
			set theFileDir to my get_sourceFolder(theFilePath) & "/"
			set theSource to the quoted form of theFilePath
			set theFolder to the quoted form of theFileDir
			set pdfCMD to pdfcrop & theFolder & " " & theSource
			set theResult to do shell script pdfCMD
		end if
	end repeat
end run
on get_sourceFolder(theFilePath)
	set tid to AppleScript's text item delimiters
	set AppleScript's text item delimiters to "/"
	set theReturn to (text items 1 through -2 of theFilePath) as text
	set AppleScript's text item delimiters to tid
	return theReturn
end get_sourceFolder
JJW
Use an Automator Quick Action with a shell script to handle the OCR process, just right-click a file and run it. Set it to save the output in the same folder with your preferred naming format. If you want drag-and-drop, a simple AppleScript wrapper could work too. Keyboard Maestro is also great if you want more flexibility!
This is exactly how I do something similar with a few PDF shell scripts. I have the Shortcuts set to appear in the Quick Actions menu.
An embarrassment of riches. Thanks all! I’ll need to decide how important it is that the approach work on older OSes (which could rule out Shortcuts), and how much ease of implementation matters — l’ll probably be sharing this with others, some of whom may not be as tech savvy.
All of which is to says, this is great feedback. Thank you!
