Hi gang - quick question, any recommendations for a comprehensive reference for markdown? Yes, I’ve searched but haven’t found anything satisfactory.
Thanks in advance!
Thanks in advance!
The thing is that there is not much to learn.
One option is:
From John Gruber himself:
https://daringfireball.net/projects/markdown/basics
Keep in mind that some formatting you might expect is not available in standard Markdown. If you need those formats, you’ll have to use a flavor of MD that has extended features. MultiMarkdown (MMD) and Github-flavored MD are two popular ones you may run across.
From MMD‘s site:
MultiMarkdown adds these features to the basic Markdown syntax:
- footnotes
- tables
- citations and bibliography (works best in LaTeX using BibTeX)
- math support
- automatic cross-referencing ability
- smart typography, with support for multiple languages
- image attributes
- table and image captions
- definition lists
- glossary entries (LaTeX only)
- document metadata (e.g.
title,author, etc.)
If you’re an R user (or not), see also rmarkdown, bookdown, thesisdown, blogdown, and probably others.
sigh
Brett Terpstra and I had written a nice¹ one … maybe not fully comprehensive but we aimed for the 90% of the stuff that 95% of people would need to know to get “good” at Markdown.
Of course now it’s gone because TUAW died.
¹ (IMO.)
like the footnote! neat.
