Monitor for M1 MacBook Pro - hi all I am deciding to purchase this monitor from Best Buy… https://www.bestbuy.com/site/lg-27ul600-w-27-ips-led-4k-uhd-freesync-monitor-with-hdr-displayport-hdmi-silver-white/6329956.p?skuId=6329956 … it seems good enough and gets decent reviews and I also have a 27 inch iMac for when I really need crystal clear screen
quick question for you all because this group is great and always so knowledgeable… Am I better doing the HDMI to USB C adapter or display port to USB C adapter?
Thanks !
I had that monitor connected to my work MBP and found HDMI to work better. I wouldn’t recommend buying it because it loses contrast if it has too much white on the screen for too long.
Interesting. Thanks for the feedback
I have the UN version on my MBP16in. I have not noticed a loss of contrast, which is not to say that this does not happen. I toggle through various settings of contrast with display modes depending on the background lighting conditions. I connect through a high-quality USB-C to HDMI adaptor. Some multi-port USB-C to HDMI dongles will not give you all options on the monitor control. I believe the best choice for assurance is a high-quality USB-C to display port cable, though I have not tested this.
JJW
Thanks. I think I have high quality versions of both cables. The HDMI- USBC cable is the Apple Branded Version. Ive heard that HDMI is a TV signal and better for TV’s and can be finicky on computers - especially Apple Computers
… Im curious if you guys know which is “supposed” to be better - HDMI or Display Port…
Thanks again for the advice
As far as I have understood, HDMI does not always guarantee support for 60Hz at 4k. Display port does.
JJW
