It does not happen often. Except when it does: you stumble upon a little tool, a nice app. For your menubar. Because you can’t have enough of apps like that. It happened today to me:
If you are using external monitors, this app can change how you interact with the monitors’ controls.
From the app’s Github page:
- Control your display’s brightness, volume and contrast!
- Shows native OSD for brightness and volume.
- Supports multiple protocols to adjust brightness: DDC for external displays (brightness, contrast, volume), native Apple protocol for Apple and built-in displays, Gamma table control for software adjustment (recommended for OLED), shade control for AirPlay, Sidecar and Display Link devices.
- Supports smooth brightness transitions.
- Seamlessly combined hardware and software dimming extends dimming beyond the minimum brightness available on your display.
- Synchronize brightness from built-in and Apple screens - replicate Ambient light sensor and touch bar induced changes to a non-Apple external display!
- Sync up all your displays using a single slider or keyboard shortcuts.
- Allows dimming to full black (advanced feature).
- Support for custom keyboard shortcuts as well as standard brightness and media keys on Apple keyboards.
- Dozens of customization options to tweak the inner workings of the app to suit your hardware and needs (don’t forget to enable
Show advanced settingsin app Preferences).- Modern, stylish and highgly customizable menulet reflecting the design of Control Control introduced in Big Sur.
- Simple, unobstrusive UI to blend in to the general aesthetics of macOS (even the menu icon can be hidden).
- Supports automatic updates for a hassle-free expereince.
- The best app of its kind, completely FREE (donations accepted) with the source code transparently available!
