When OpenVPN Connect establishes a connection, I can manually mount a network share in Finder>Connect to Server>smb://xxx.xxx.xxx.xxx/FolderName. Yay me.
If I want to be fancy, I can also do this with an AppleScript:
open location "smb://user:password@xxx.xxx.xxx.xxx/FolderName"
Sometimes the VPN loses connection and the client reconnects automatically, but the folder is not remounted. I would like to automatically mount/remount upon OpenVPN Connect connecting to the VPN, and I think this can be done by pointing to a script in the config fie, but we have reached the outer limits of my knowledge and ability to Google.
Thanks. I saw that, but oddly enough I was not able to get connected with Tunnelblick when I set things up, so I went with OpenVPN Connect. Resolving that may turn out to be easier.
I bought Automounter and the “pro upgrade” for a total of $13.99. So far, so good.
When I connect to the VPN, it mounts the share with the correct user and remounts when I disconnect/re-connect.
I was reluctant to post such an edge-question here, but I can’t tell you how much googling and reading I did without uncovering this solution. Thank you!
