MS Outlook crashing on print
When I try to print a calendar from MS Outlook it will hang and crash after I cancel the print job.
It prints the emails without problem
I tried all the following options:
  • Checked of updates
  • Restarted the Mac
  • I recreated the Outlook profile
  • Completely uninstalled MS Outlook and all its supporting files in the user profile
  • Reset the printer system
Any idea’s ?
check printer vender for reports of the issue and if they have an updated or another printer driver. Brother gave me a link to an older version than provided in macOS and it fixed the issue I had with the printer driver provided in the macOS.
But everything else prints fine even email from outlook…
Outlook also crashes when I save the agenda as a pdf from the print menu…
OK. I still think you should contact [un-named by you] printer manufacturer. Simultaneously, good to contact Microsoft about this.
I have the exact same issue that has just started. No change to printer driver. It must be related to Outlook right? Please let me know if you find a solution.
