I’m actively working on getting myself into the habit of more deeply scrutinizing device purchases and such. In particular, I’m starting to make more detailed notes about where Current Self’s thought process is, so Future Self has a clue how I got where I’m at. ![]()
For example, a ways back I was looking at getting a new pair of PowerBeats Pro, because my old PowerBeats Pro were broken. But before I did, I decided to take some time and really come up with my use cases. I mean, if I’m replacing multiple pairs of headphones every several years, that really starts to add up!
What I came up with is that I basically have three broad “use cases” for headphones, and two “device cases” - i.e. “which devices they need to work with”:
- “I need everything quiet.” Meetings, “head down” type focused work, etc. These need to be excellent at noise-cancelling, be able to make clear phone calls, and work with both my Mac and my phone.
- “Something to listen to while I’m going to sleep.” These only really need to work with my phone as well, but it’s a bonus if I can put YouTube on the Apple TV and fall asleep to it.
- “I want to listen/talk while I do other things.” Washing dishes, walking the dog, etc. These also need to be able to make clear phone calls, and only need to work with my phone.
Looking at years of buying/being unhappy/re-buying/etc. of headsets, I’ve found that these are the minimum, and every time I try to compromise any significant component of these I tend to get frustrated.
The first two categories are currently “on cruise control.” And even if they weren’t, PowerBeats Pro aren’t useful for either. They don’t have noise cancellation, and they’re too awkward/bulky for the sleep aspect.
For reference, my “I need everything quiet” headphones are the AirPods Max, with this charging dock so I can easily pick them up/dock them for charging. If I’m on a plane, or away from my computer, rather than traveling with the bulk of the Max I use AirPods Pro with these ear hooks to keep them from working out of my ear. I hook them to my keyring with a cheap rubber case that takes a Python Clip.
For the “something that unobtrusively fits in my ears while I’m going to sleep,” I also use AirPods Pro. They fit nicely, they seem to fall out after a couple hours, and I just pick them up in the morning and put them in the case. I’ve looked at alternatives like sleep headbands, but honestly they’re usually too thick as a side sleeper, and they make me sweaty/itchy.
Which brings me to “I want to listen/talk while I do other things.” This category is where the PowerBeats Pro used to live, until a bit over two years ago when I got a Shokz OpenComm. The OpenComm was great, but Bluetooth stopped working reliably - and just outside the warranty period. No repair, no parts, nothing. Disappointing quality when new OpenComms are in the $200 range.
I tried just using the AirPods Max. They technically do everything required - but they’re heavy and make my ears sweat when I wear them for 8-10 hours at a time.
I also tried just using the AirPods Pro with the little ear hooks. These worked, but the battery life isn’t anywhere near as good as either the OpenComm or the PowerBeats Pro.
And then I remembered the reason I’d gone to the OpenComm in the first place. A few years back, I’d started having hearing issues due to wax build-up. My doctor suggested that I come up with something that didn’t go in my ears for “all day, every day” use, and that resulted in the research process that got me the OpenComm.
Add that to my last use case, and the PowerBeats Pro failed on all three counts. Plus, they were Lightning - and I really didn’t want to purchase another Lightning device. Which also got me thinking - the OpenComm use a goofy proprietary dongle, which takes up even more space in my travel setup. What if I could get “close enough” to OpenComm and come up with something that used USB-C?
After some online research, I wound up replacing the Shokz with this Monodeal headset. $60-ish, and for another $10 Asurion warranties them for 2 years. The Monodeal have a USB-C port right on the device, and they’re not bone conduction - but they don’t obstruct the ears, they sit very loosely, and they’re very comfortable. So far these are a very pleasant surprise, and 1/3 of the price of Shokz.
I’m storing my thoughts on this, as well as the criteria, in a document for Future Self so I don’t wind up burning too much time re-thinking this in the future.
Does anybody else get spun around on things like this sometimes? Any thoughts other than “write it down, so you remember it later?”
