My iPhone 12 Pro Max has two Docks
On my iPhone 12 Pro Max, there is the dock at the bottom of the home screen. I would expect it to be there.
But there is something behind it. It might be a second dock. I didn’t put it there.
I can’t tap it. I can’t drag the main dock out of the way.
How do I get rid of it?
I’ve attached a screenshot of the bottom portion of the home screen.
Thank you,
Todd
![IMG_3952|669x500](upload://2y
gE9OTO204kZj2I4zr6ge0Qqj8.jpeg)
Try turning off or changing the wallpaper.
Thank you quorm for that suggestion. It worked!
Instead of the monochrome background, I selected one of the image-type backgrounds.
Then the extra dock went away!
Great. Glad that worked. I suspected that you had inadvertently taken a screenshot and made it into the wallpaper for the phone.
Think so too
Seems it’s an iPad screenshot from the nr of apps and folders
