Hi, I have some keyboard shortcuts assigned to option + C, option + W etc. In text field area instead of activate keyboard shortcut, I get special characters like ç Ω. Very annoying when I write in drafts and need to move focus first to activate the action.
Maybe someone know how to disable this special characters feature? Have installed karabiner if it will makes it easier
I would second this. The option key is primarily made to alter the function of the part of the system you operate, and that has been special characters since the beginning of Mac OS.
Ah, so that’s actually a good thing to know: whenever you find yourself thinking « shouldn’t it be possible to do x or y ? » try the menus with the option key down. It often reveals a slew of advanced settings.
Or when Apple changes things to make you try new features. For example, when tabs were introduced in finder windows, right click and “open folder in new window” got changed to “open folder in new tab.” If you hold down opt, you get “open folder in new window.”
