Notifications and Fastmail
How are you all handling notifications when using Fastmail? I like how when using gmail you can choose to get “important” notifications and it sort of decides… usually correctly.
on my mac , I use Fmail. I have the icon (with the badge number on the menu bar only, not individual notification for each incoming email
on my iPhone / iPad, I also only enabled notification center and not each incoming email
On Fastmail, I understand that you can set up sender as VIP , but I am not sure whether you can use this to automate the notification process.
Recently @RosemaryOrchard talked about using Integromat on this episode but I have not tried it yet
I disable notifications completely, like I do for 99% of my Apps…
They do have proper native iOS support for them though:
