Numbers: Lock a certain sheet
Does anybody know, it is possible to lock a certain sheet in a Numbers file?
That is, it should not be possible to edit data there, fill its cells with colors, or change cell sizes.
You can lock a table.
You can lock a table so that it can’t be edited, moved, or deleted.
  • Lock a table: Click the table, then choose Arrange > Lock (from the Arrange menu at the top of your screen).
  • Unlock a table: Click the table, then choose Arrange > Unlock.
If your sheet contains only one table, then I suppose you have in effect locked the entire sheet.
