I am trying to use the Pandoc plugin but it is not showing the export option. I have it installed and enabled. I’ve followed the basic instructions but it does not show up when I use the command pallet. Below are two screenshots and the Pandoc instructions. Any suggestions?
INSTRUCTIONS
Obsidian Pandoc Plugin
This is a Pandoc export plugin for Obsidian (https://obsidian.md).
It adds command palette options to export your notes to a variety of formats including Word Documents, PDFs, ePub books, HTML websites, PowerPoints and LaTeX among (many) others. This is all thanks to Pandoc.
This lets you write presentations, draft books, make webpages, and write assignments all in Markdown, and export to whichever format you fancy, all without leaving Obsidian.
Note: this plugin is in beta, and there are often minor formatting issues. Make sure to proof-read the output!
Installation
(Installation instructions are on the wiki, use the above link)
Basic usage
- Press Ctrl+P/Cmd+P to show the command palette
- Search “Pandoc”
- Choose your export format
- If all goes well, it will say it was successful
- If you exported a file called
Pandoc.mdas a Word Document, in your file explorer there will be aPandoc.docxfile in the same folder
