hopefully you can help me with a solution to my “challenge”.
I’m a user of both Mac’s and Windows PC’s, and in this connection I’m making use of the OneDrive application for file management, and was wondering if it would be possible to have the Desktop “folder” of my Mac use the same “Desktop” folder as I’m using on my Windows PC (and found in the OneDrive library).
There is no way I am aware of to really show the Windows Desktop Folder on your Mac or your Mac Desktop Folder on your PC. Both folders are deeply baked into the operating systems and they need to be where they are.
But… It can be done as long as you are fine with duplicate files (see below).
A not so elegant solution would be to sync those two folders on your Mac using a tool like Hazel (User Guide) or ChronoSync or a similar tool like that.
Both tools are able to exclude files you might not want to be synced (examples are thumbs.db from your Windows Desktop or “hidden” files from your Mac desktop like .DS_store).
Downside: you will end up having duplicate copies of the files on the Mac that is doing the syncing:
The files will sit inside your OneDrive Desktop folder (Windows Desktop folder).
The files will also be inside your Mac Desktop folder (which may or may not be your iCloud Desktop folder).
