'Open with...' menu help please
Does anyone have a tip for cleaning up the ‘Open with…’ menu in MacOS? See below, I have got a load of rubbish from Microsoft Edge. How do I remove it and just leave the latest version? Thanks all.
Booting into safe mode should rebuild the launch services DB or you can do it in something like Onyx.
Assuming you don’t have all those versions of Edge installed :slight_smile:
And with Service Station you can customize the other services if you want.
Is Service Station still being developed? I get an abandoned ware vibe.
I had been using it since it was released but recently deleted it as it was not working for me.
YMMV
Yes, I feel you… It’s been already a long time that I’ve seen an update…
You could try the Onyx app for this. Maintenance > Rebuilding > Launch Services database. Worked for me to clear “Open with” about a year ago, but sorry, I don’t remember any details about what exactly I tried to fix there.
Thanks all for the help. I have run the Launch Services re-build in Onyx but it does not seem to have fixed the issue. Will keep on investigating…
