I connected the OWC Thunderbolt Hub to the M1 mac mini. Once done, things went downhill. Waking the mini up from sleep took at least 1 minute. Once logged in, istatmenu showed the left 4 cores quite busy for some time. The mini itself felt slower. After several days, I disconnected the OWC Thunderbolt Hub and now the mini is back to its former performance. Do you guys see problems with this combo as well? Maybe I just have a faulty unit.
I’ll be returning the Hub, but can anyone recommend another Hub that seems to be “optimized” for use with M1?
Oh! I just received my OWC Hub few minutes ago and I am planning to use it with my M1 Mini. They specifically marketed it as M1 compatible hub.
I will test it for few days and report back.
Would you mind me asking which one you were using?
This is what I got and what I have problems with: OWC Thunderbolt 3 Dock - 14 Ports, Silver. Note: I don’t even have a monitor plugged into the dock (it’s plugged directly into the mini), only 1 external USB-C drive (with the intention of adding more, which I cannot do now)
Thanks for sharing that. This is the one I ordered and received today (I didn’t even have a chance to connect it yet).
It is specifically positioned as M1 compatible.
