I once had an issue where my Hue lights decided I was arriving home at 2am, and then again when I turned them off, and again, until 2:15am at which point I turned off the regular switches, tweeted at the Hue support and went back to sleep.
Which is to say: It might be something that’s not a time based trigger? Do you have any other automations that turn on your lights? Try disabling them one at a time (or all of them and enabling one at a time) to see if this keeps happening. Also, the Hue support folks did get back to be really quickly when I had my issue!
Thanks @RosemaryOrchard, that’s a good thought. I don’t have any automations (arrivals, etc. ) for these two lamps.
That’s a good idea @JoePreiser . I’ll have to check the others (all downstairs) and see what they’re doing. We have had all lights come on after a storm. Could be the power company playing games at night working on a problem.
I looked around and don’t see a setting for power-on behavior in the Hue or Home apps.
