Perhaps a touchscreen MacBook Pro? I’ll admit that, like others I’m sure, I often find myself poking at the MacBook screen as if it was an iPad. Momentary madness, for sure.
But do I really want a touch-screen Mac? Hmmm , probably not, maybe yes … probably not … not sure …
I don’t feel like I’m missing anything for not having a touchscreen MBP. Indeed, while a touchscreen is nice with a 10" iPad paired with a keyboard, a full-sized notebook might be too big to reach across.
However, I’d love an iPad that could run MacOS, so I could then run grownup apps. Please please please. I’m tired of being stuck in the kiddy pool when I’m using my iPad.
The true pro-level feature would be a built-in cellular data modem?
I don’t need a new laptop now, but knowing that modem options were/are finally available, would let me plan to not replace my aging iPad Pro as the ability to use something other than Wifi or tethering is the one limitation of Apple laptops that still has me grab my iPad once in a while.
Cellular data modems in laptops would be fine if they were based on a DSP model and not on a fixed hardware model. The problem with cellular data modems in laptops is the hardware modem has to be certified for the region of the world in which it’s going to be operating in.
That means if you were in EMEA, which is Europe, Middle East and Africa, you’d have one set of regulatory bodies looking at the modem. If you were in North America, you’d have another set and if you were in China, you’d have a third set and if you were in Japan, you probably have a fourth.
If you were going from a 4G LTE to 5G modem, you’d have to get certified all over again. Now, if there was a way you could use a DSP device and work the hardware features into software, the software changes would need to get certified again and you could update it over the air.
The antenna would have to be designed for multiple generations of cellular service, which might be difficult
My 10-year-old daughter has a touchscreen laptop at home. Occasionally, I help her with things. Neither one of us has ever been tempted to touch the laptop screen.
I haven’t followed the nitty gritty details in cellular standards and per-country requirements for more than a decade, but isn’t this a solved issue?
I can get an eSim for my iPhone for almost any country I want to visit, download and activate it, and have a working cellular data connection in seconds.
I see no problem in doing the same with an Apple laptop.
Lastly, even if there is a bureacratic or technological challenge, Apple is certainly large enough with both the resources and arm-twisting carrier relationships to make it happen.
Purely a design/business decision that Apple should make - no real insurmountable barriers.
