Hi,
I was used to be able to drag/move/edit etc. files on my desktop when I used interactive corners in Monterey. I have “desktop option” set as my bottom left corner and from there I was used to drag files from the desktop in email for instance. When I was typing a mail and I needed to add a file from my desktop to the email, I would go to the bottom left corner and select the file on the desktop and then drag it it to the top right corner and the email open windows pop up again (“mission control option”), and I could add the file to the mail. However it appears in Monterey that my desktop files are “locked” when doing so via interactive corners. I used this workflow at least 30 times a day or so… this is so frustrating.
I hope I explained the issue clearly. Would love to here if I can fix this or if there is a better workflow…
Best, Maarten
