Love the speed of the Drafts app for input and rock-solid sync, but find processing notes and deleting them to be cumbersome. In my experience, it is not possible to delete with the iPad keyboard, PLUS it takes a swipe and tap to delete each Draft. Is there a way to auto-delete Drafts once they are exported to Notes, OmniFocus, etc?
You can specify what to do after success on a per action or per action group basis in Drafts, so I have several actions which will archive or trash the draft when they’ve been successfully completed
If you are doing the processing on an iPad, you can slide over the draft list and pin it. Makes it easier. I would definitely recommend setting up per-action options for archive & delete. There is also the select option at the bottom of the draft list, where you can batch process drafts to the archive or trash.
