Recommendations for a portable monitor for M1 MacBook Pro
The title says it all. I am looking for a portable monitor to use with my M1 MacBoook Pro. I’ll be using in during livestreams using Streamyard, as well as for some editing in iMovie and basic design work in Canva.
Prices and specs are all over the place, so turning here for some recommendations.
Thanks!
What size are you looking for? If you have an iPad, could you use that with Sidecar?
Looking for 15 inch or so.
I don’t have personal experience with one, but maybe this will help:
I went down this rabbit hole last month. It depends on budget, resolution. The Asus Zenscreens are pretty popular and you can get a Like New one on Amazon for around $60 if you want to try one out. The only issue is most of them do not have pass through charging. So it will take up one Thunderbolt port on your MacBook.
The Lenovo M15 looked like a good option with pass through charging and a built in stand. The Zenscreens have a case that doubles as a stand, it is passable but not great. Some have a tripod mount that you can use if you want to have the screen elevated. ViewSonic had some good options as well.
