I’ve heard a number of folks on Relay rave about the CalDigit hub, possibly even on MPU.
I’m also sort of in the market for a hub that’s got USB-A ports, power pass-through, HDMI, an SD slot, and optionally Ethernet - and compatible with both my M1 Air and Windows 10. I have an Anker that covers most of those but the HDMI doesn’t play nice with my work laptop. So I’ll be watching this thread and taking notes
The Hyper hubs do all of that but are limited to USB-C. I use the hyperdrive add-on docks for my MBP and iPad Pro when out and about and have the bigger one stationary in the office as a convenient 1 cable setup.
At home I went all-in on Thunderbolt. If you have one of the new M1 you should be looking at the Caldigit and OWC Thunderbolt 4 hubs to extend your options. I daisy-chained the Caldigit Element hub with the Caldigit TS3+ for all the I/O I will ever need. It is not a mobile solution though.
I’ve been using the Anker USB C Hub, PowerExpand 8-in-1 USB C Adapter with my M1 MacBook Pro for months and continue to be very happy with it. While I currently only use it at my desk, it’s also highly portable (and even comes with a case).
I’m currently using this hub for:
Power delivery
External 4K monitor (60Hz HDMI)
Connecting my monitor’s USB Hub (which, in turn, connects to a Blue Yeti and Stream Deck)
4K Webcam (USB-C)
What’s great about this setup is that I still have a USB-A port available on the hub and am only using one of the two ports on my M1 MacBook Pro.
