I recently purchased a pack of 4 Refoss Mini Smart Plugs off Amazon. In reality it appears that these are a cheaper version of Meross plugs. Anyone else have experience with these? I am about to send them back as I cannot for the life of me get them to pair with HomeKit even though they are supposed to be HomeKit compatible (which is why I bought them). Here is what I have done:
I have disabled the 5GHz wifi on my network so that my iPhone 13 Pro Max running iOS 15 is connected to the network using 2.4GHz wifi as required.
I have also verified that the the mini smart plug is connected to the network and the LED is blinking amber/green indicating that it is in setup mode.
I have attempted to add the accessory both directly into HomeKit (which the manual says you can do) and through their iHomeLife. Each time I try to add the plug I get an error stating that the “accessory is not available.”
I have repeated attempts to add the plugs after resetting my router as well as doing a factory reset on the plugs. None of this has worked. Ocassionly, but not always, I will hear the plug turn off then back on during attempts to add it to HomeKit but installation never completes.
Here are my suspicions:
For some reason the plugs are not compatible with iOS 15. Have you tested this?
My network is a mesh system using three Amazon Eero Pros and am wondering if the mini smart plugs have issue with this. This has never been a problem with any other accessory I have added, but these are the first that do not require a hub which might be part of the problem. I have attempted adding the plugs to HomeKit when I know that both the plug and my iPhone are connected to the same Eero Pro.
Any thoughts anyone might have would be appreciated.
