I saw in this post that someone re-mapped their right command key to be SHIFT+CONTROL+OPTION+COMMAND all at the same time.
How do you do this?
How do you do this?
And wouldnât you be better doing that to the Caps Lock key?
I recently realized that I almost never use my right Command or Option keys, so itâs possible the OP uses their Mac the same way.
I have my Caps Lock set to a âhyper keyâ but now I also use those right two keys for specialized tasks (Right-Command = Quick Enter Drafts, including launching Drafts if needed, and Right-Option = Quick Enter Fantastical, including launching Fantastical if needed ).
Using Keyboard Maestro? Whatâs your end to end setup for this?
I have taken a few stabs at a shortcut to show/hide Drafts (using the same KM macros that seem to work fine for all other apps) but canât seem to make anything work reliably. Most of the time Drafts remains hidden. (It may have something with un/plugging from my dock. That seems super flaky in many ways with MBP16/Catalina/whatever.)
Are you remapping a shortcut key that is set in Drafts preferences? Or do you have that unset?
I am using Karabiner to map right-control and right-option to F-keys (I think F18 and F20, as F19 was already in use for my caps-lock hyper key.
I tend to do the same thing for any app which has a âglobalâ key:
make a Keyboard Maestro macro that uses that same key
in the macro, I use an if/else action which says "If the app is NOT already running, then launch the app, pause until the app is running, and then execute the keyboard shortcut again.
in the macro, if the app IS already running, then I donât have my macro do anything, and the keyboard shortcut should just be passed along to the app.
So, for example, here is my Drafts shortcut:
Note: Click to embiggen. Also, the âPause for 3 secondsâ is probably too long. Adjust to your Mac.
Note that ââ§1 is Draftsâ default keyboard shortcut, so I use that, but I also use F18 (which Karabiner has mapped to my right-command key).
Does that help? If not, feel free to ask.
If you want to use my macro as a starting point, you can download it here.
So the net of it is: The more hyperkeys you can devise the better.
Precisely! Especially because you can do things with Karabiner such as:
If I press this key (e.g. right-command) by itself, then it equals âF18â
If I press this key plus others it equals âcommandâ
which means that you donât lose the regular functionality, you just gain a special key that you can use for your own purposes. Each of these can be made to do âdouble dutyâ:
If you are reading this but arenât familiar with Brett Terprstraâs instructions, you can find them here:
A Hyper Key with Karabiner Elements, full instructions - BrettTerpstra.com
Exactly on the double duty. You can do it with other keys, too. For example, I have function keys mapped to the F key + a number key. So F = F, 8 = 8, F+8 = F8 function key. Super handy on the MBP with touchbar.
