On macOS, I use Chrome as my default browser (long story) but sometimes I’d like to open a link in Safari.
Is there an easy way to add that option. Perhaps a right-click with a context menu option to ‘Open Link in Safari’
Any advice appreciated.
This might be helpful.
I recall there are others too.
I use Bumpr which is like Browserosaurus. It also comes with a chrome extension for choosing a different browser to open the current tab in.
Edit: https://chrome.google.com/webstore/detail/bumpr-extension-for-chrom/njkekafaidebinelgdobnpbijknfnlef
I have tried both of the above but my facourite remains Choosy. It’s a great app.
If you want a right-click solution you might want to try making an Automator “service”.
Thanks for the links and advice. Much appreciated.
I have used Keyboard Maestro to create a macro for this. I have two versions which allow me to open a Safari tab in Chrome and vice versa. Have linked them to Stream Deck buttons and so far have found that I am using them a lot.
Can post the macro if anyone wants it.
@KirkS see below. Really simple macros but it is amazing how useful these are. I have a couple of others which just the grab the URL from the browser and put it in the clipboard - again very useful.
Send Safari page to Chrome
Send Chrome page to Safari
The ‘play sound’ is not really needed but I often add this to the end of my macros to make sure they are running ok!
