This.
It’s the equivalent for defining and calling a function.
Model-view-controller, right? Update the model and the views update themselves. Just like multiple people editing a google doc. If Cautious Camel makes a change, Amorous Aardvark and everyone else can see it.
@anon41602260 seems reasonable to me. It just means databases. I have three myself. But honestly, the only reason I would need more than 1 is to have one for private and one for public use. In the future, once page permissions are perfected, then you don’t even need two for public/private. Other than this distinction, I don’t see a reason to have more then one private database (graph) - interested if there is disagreement here.
I see a use case for separate databases. I’m a fiction writer and I have several DEVONthink databases for that reason: each story world (I write SF&F, but you can make the case for mainstream fiction) is fictional and therefore, you would not want to either mix them up together or mix them with a knowledge repository such as a Zettelkasten. For instance, I could have info about real world research on interstellar propulsion, and then two different fictional worlds where interstellar propulsion works differently from one another. Put them all together and you’re bound for trouble, I believe.
By the way, DEVONthink offers the best of both worlds on that front: automatic wiki linking inside a database, which can exist as a silo, but you can still link manually to any file inside the software outside of that database. (Don’t know if Roam allows for that)
I think that’s what happened with the Challenger…
Edit: These prices are by no means excessive for a good tool, by the way. I just don’t know if it is the right tool, since I apparently have to pay to try it.
I hold all my files outside in DEVONthink and just use a markdown link to open the item-link when needed. The only reason I am using Roam instead of devonthink or Notion is block level/inline transclusion, page filters and queries. Though the sidebar is quite useful too.
