Safari Bookmarks Not Syncing
Hello to all. I am having this never ending struggle with bookmarks not syncing between macOS and iOS on both public and beta software versions respectively and have had to go to a different browser to reliably have sync. Have any of y’all had this problem and have y’all figured out a way to fix it?
Yes, have seen it for years. Continuing. I have no solution, other than “wait and hope”.
… which sometimes seems to be the successor of “it just works”. :flushed:
Hey, you can follow the given steps to resolve the issue, it might help.
  1. Firstly take backup of your existing Bookmarks.
  2. Make sure you have logged in with same Apple ID across the different devices.
  3. Go to the iCloud settings, and check the if Safari is on for that particular device or not. If yes then turned it off and wait for few minutes then turned on again.
  4. Make sure you have correct time and date on your all devices.
