There was some change in the YouTube UI and it breaks some browsers including safari. Ton of posts on reddit and other forums. Not everyone seems to be affected.
PROBLEM: Pressing spacebar (play/pause) after switching tabs doesn’t play/pause the video and one has to click on the video to get it back into focus.
SOLUTION: Here is a UserScript that fixes that. Put it in “UserScripts” extension and that’s it. Also took inspiration from: GitHub - MrQuackDuck/CorrectPause: Firefox & Chrome extension that fixes YouTube issue with pressing Spacebar to (play/pause) videos..
// ==UserScript==
// @name Enhanced YouTube Spacebar Control
// @namespace https://www.youtube.com/
// @description Controls YouTube play/pause with spacebar while avoiding interference during typing.
// @match https://www.youtube.com/*
// @grant none
// ==/UserScript==
(function() {
'use strict';
let latestAction;
// Elements on which pressing space won't play/pause the video
let forbiddenElementsSelectors = [
'input',
'textarea',
'#search',
'[contenteditable="true"]', // General selector for editable content
'.ytd-searchbox', // Specific to YouTube search boxes
// Add other selectors as needed
// Helper function to check if spacebar interactions are allowed
function isSpaceAllowed() {
return !document.activeElement.matches(forbiddenElementsSelectors.join(', '));
document.addEventListener('keydown', function(e) {
if (!isSpaceAllowed() || e.code !== 'Space') return;
let vid = document.querySelector('video');
if (!vid) return;
if (vid.paused || vid.ended) {
play(vid);
} else {
pause(vid);
e.preventDefault(); // Prevent default scroll behavior
document.addEventListener('keyup', function(e) {
if (!vid) return;
// Repeat the action to ensure consistency, based on the original extension logic
if (latestAction === 'play') play(vid);
else if (latestAction === 'pause') pause(vid);
function play(video) {
latestAction = 'play';
video.play();
function pause(video) {
latestAction = 'pause';
video.pause();
