I’m wondering if anyone here has any experience using this monitor with a MacBook Pro M3 Max. I just ordered one, along with a Cable Matters 32.4Gbps USB C to DisplayPort 1.4 Cable.
First off, congrats! Those are fantastic panels. I just purchased a 38in monitor after a recent thread here. Sadly it’s non-OLED, but I’m enjoying it quite a bit.
Make sure you are getting the maximum refresh rate in display settings. Sometimes it defaults to 60hz when you could be outputting 144hz.
Try out some display managers if you don’t have a preferred one already. I like Magnet for snapping windows and doing layouts but there’s also BetterDisplayTool, Moom, and several others people enjoy.
Thanks for the tips!
I read that the image on that monitor is pretty blurry (in a Reddit thread - https://www.reddit.com/r/macgaming/comments/1ayd4bb/transitioning_from_windows_to_macbook_pro_m3_max/).
The user wasn’t happy about the text. I’ve no personal experience with one.
I ended up returning it for that reason. I’ve been used to used two LG Ultrafine 5K monitors, which are retina level. I’m spoiled. I found the text on the Samsung to be difficult to read, even at it’s highest resolution.
