JasonB
July 15, 2019, 3:15am
1
I have a number of scenes set up in my home with Phillips hue.
I’m thinking of getting some lutron caseta dimmers and adding them to the mix.
Can you set a specific dimmer setting when creating a scene with the lutron switches, or is it a binary on or off setting.
I would assume/hope it’s possible, but haven’t been able to find an answer by googling it.
Not sure exactly what Caseta unit you have in mind, but mine all have the ability to set an exact percentage in the HomeKit automation.
Mulvie
July 15, 2019, 6:21pm
3
I’m really happy with the 4 Lutron Caseta dimmers I have in my home. (Wireless Dimmer Switch for Wall and Ceiling Lights, Model # PD-6WCL-WH).
All of them work perfectly with HomeKit, and include the ability to create scenes with specific dimmer settings.
Do you use LED bulbs? I cant get these things to work at all.
Mulvie
October 13, 2019, 7:13pm
5
Hi Brandon,
We have a mix of LED and standard bulbs in our home and haven’t had any problems. One tip if you haven’t already tried is to make sure your LED’s are labeled as dimmable. Apparently non-dimmable bulbs can cause problems.
