Schneider bring retrofit Square D Control Relays
Schneider is moving strategically in the burgeoning Smart Panel arena.
First - The Energy Center which is a Meter Main Combo that’s primarily pushed at New Construction external MSP.
Second - The Pulse Series with new Inverter and Battery system. Essentially 2nd Gen Energy Center
Third - The “Retrofit” solution with the new Square D Control Relays which pop into a standard Homeline or QO (I presume) panel.
@SpivR Do the Control Relays look familiar to you? I know of another company that has that same form factor.
