Hi All,
Does anyone know if there’s a way to share contact info for an entire group as opposed to sharing individual contacts one by one? The share sheet doesn’t appear when a group is listed. I’m on iOS.
Thanks!
The iOS version seems to only let you share/export one card or all cards.
On the Mac you can Command-click select multiple discontinuous cards (or shift-click to select the contents of en entire group) then drag the selection out to a folder to export individual vCards. On the Mac you can also create a Smart Group then share it by right-clicking the group in the Groups column, then clicking Copy Smart Group URL.
Excellent - thank you!
