You can see this is a 5-click process.
How can I reduce this to a set of hot-keys?
Note: You may be thinking about the Develop menu item Clear Caches ( option+command+E) This, unfortunately, does not remove the Website Data as mentioned above in the Privacy preference. Maybe there’s a way to make it do so?
Thanks for the suggestion.
That KM macro and what I’ve looked at for Alfred workflows both seem to rely on scripts.
I will try to pursue the Alfred angle, as I have more familiarity with that app, but the scripting looks more complicated and beyond my level.
I thought the Shortcuts app was made for doing this sort of thing without having to write scripts, but so far I’ve had no luck using Shortcuts.
