I am not very skilled in Shortcuts. However, I have been diagnosed with an autoimmune disease, that requires me to do something called the “Elimination Diet”. I am wanting to create a Shortcut to help with this, and store everything in an existing spreadsheet. Here is what it would need to do:
Column 1: I need the Shortcut to auto-populate the date & time.
Column 2: Would be a text field with what I ate.
Column 3: Also, would be a text field with medication taken.
Column 4: Would be a symptom checker with a scale of 1-5.
Column 5: Would be a text field for Notes.
Is this even possible? I’m in the car 6-8 hours a day, and I’m looking for an easy way to capture this information. Thank you for any help/answers.
Numbers on iOS has a forms feature. You may be able to use that as an easier way to input data until someone helps you with a way to do it with Shortcuts.
