Is there a way to organize the order in which Shortcuts appear on the screen? I would like a couple of translation shortcuts to appear at or near the top (at least temporarily) so I don’t have to scroll to find them while on vacation.
at the bottom of the widget there’s a button that opens a rearrange interface in the shortcuts app
That doesn’t appear on my phone. However I just discovered if I tap and hold I can move the icon for a particular shortcut around to where I want it.
yes, inside the app that’s the way you do it
the button in the widget should appear if you tap “show more” in the upper right corner of the widget
