I sometimes copy a bunch of files to my Mac’s internal drive. I also have a new external drive plugged-in. What’s the simplest way to have macOS automatically mirror/copy files from a folder on one drive to a folder on another? I’m not really looking for a formal backup strategy here. But I guess some kind of rule maybe? Thanks in advance!
Do you use a backup app? Many backup apps like Carbon Copy Cloner, Resilio Sync and ChronoSync will let you select parts of a drive you want to clone, down to the folder level (and of course on subsequent runs will only copy over changes after the first copy).
Otherwise there are folder-sync apps aplenty, like Good Sync, but the better folder-sync apps cost $30-ish, close to that of a good backup app.
If you’re cheap and are willing to get geeky, look into the rsync command built into macOS - you can even automate it with Automator.
Personally, I’d just create a file-sync process in my backup utility that copies the subset of folders I want to mirror.
You can also try a sync solution like resilio sync
https://www.resilio.com/individuals/
Their free option gives you a lot to get this done already, and they’ve got a lot more in the premium tier. For my needs the free one was enough for many years, but I now upgraded to pro for some specific needs.
An app like Hazel can watch a folder and act on files that arrive, but that is more about tracking activity than maintaining a mirror. As already mentioned, apps like Carbon Copy Cloner can mirror directories, and can do so on a schedule, which may suit your needs.
A wild idea that I do not endorse as such, it just occurred to me, might be to get Hazel to set off CCC or equivalent.
There is also macOS’s native Folder Actions to consider.
Great ideas, thanks, all!
I believe that if you want to do selective sync of specific folders you need the $60 version of Resilio. CCC is $40, Chronosync is $50.
That’s selective sync only. So what NOT to sync.
I believe the question here is what TO sync. I’ve used that with the free version for years.
