Smart Stacks and Focus Modes
Does anyone know if there’s a way to link a widget in a Smart Stack to a focus mode? I use OmniFocus for work tasks and Reminders for personal ones. I would like the stack to show the appropriate widget for the Work or Home Focus Mode.
You need to create a separate Home Screen for each Focus Mode. On each Home Screen you would create a separate Stack of Widgets. Yes, that means that if your list of apps on the home screen or the other widgets in the stack are the same, you would need to duplicate them on each home screen.
Okay, so it looks like there’s no way to do it with the Smart Stack itself. Thanks!
