Sonoma 14 macOS automation for system settings via applescript and osascript
Hi folks
I am trying to run some automation to set certain settings in sonoma via osascript ( and applescript ) directly. Here are the things I am trying to do on Sonoma MacOs 14.1.1 and I cannot find the property or way to do this via tell “System Events” or another way- can someone provide an apple script with the correct settings to do this on Sonoma-and I dont want to use automator - only via the terminal and osascript to execute since this code needs to be executed on a bunch of hosts
  1. Change resolution to `1920 x 1080’
  2. Change default dynamic wallpaper and appearance :
  3. System Settings → Wallpaper → Colors → Black
  4. System Settings → Appearance → Appearance → Light
  5. Limit Terminal scrollback to set to a particular limit say 5000
  6. Change the Computer name and hostname:
  7. System Settings → General → About → Name : xxxxx
  8. System Settings → General → Sharing → Local hostname → xxxxx
  9. Disable WiFi, Bluetooth and Thunderbolt
  10. System Settings → Wi-Fi → click to disable
  11. System Settings → Bluetooth → click to disable → Turn off
  12. System Settings → Network → Bluetooth PAN → Make Inactive
  13. System Settings → Network → Thunderbolt Bridge → Make Inactive
  14. Enable Firewall System Settings → Network → Firewall → Turn On Firewall
  15. Change DNS to x.x.x.x, y.y.y.y. ( x and y are just values) - its the DNS applescript cmd
  16. setup automatic login to a particular user
  17. Disable screen saver
    System Settings → Lock Screen → Start Screen Saver when inactive → Never.
    System Settings → Lock Screen → Turn display off when inactive → Never.
thx much.
what I was able to figure out from the list was only the appearance light with this script but need assistance with the rest of it.
tell application “System Events”
tell appearance preferences
set dark mode to false
end tell
end tell
