I have two Fujitsu Scanners
S1500M
S1300
MacBook Pro 16" Intel 2019 attached to the S1500M
MacMini M2 Attached to S1300
Both of these Macs run Sonoma.
I cannot get either to work. Downloaded the most recent software for both from now Ricoh which apparently bought out Fujitsu. There is a failure at the step to detect the USB connection on both setups.
These machines have been workhorses. There have been repeated software issues with the hardware cast into varying degrees of limbo.
Throwing away functioning hardware because of lack of software updates is depressing. My S1500M most recently had been functioning on a 2014 iMac running Catalina but that iMac finally died. Similarly, the S1300 was running on Catalina with a 2011 iMac which still works but I replaced with the new MacMini. I do not have the physical room in my life to dedicate a 2011 iMac to the sole task of scanning.
Is anybody successfully using these Fujitsu scanners with Sonoma? Any hints? Source for alternate software?
